Ground wires and grounding the block
were is the best place's to ground the motor? isn't it battery to frame, frame to motor, motor to the body or fire wall? is there more, or did i cover it?
I've got the negative battery cable to the frame, each side of the block to the frame motor mounts, and each head to the frame. Overkill? Yes. But at least I know my **** is grounded..
Tails
Tails
