98 ls1 with m6 wiring diagram?
I have searched around but never found a wiring diagram for a 98 ls1 with m6, maybe I over looked it or something but if someone could help me out that would be great! Thanks,Brandon
ok i found the 1998 pin connections,wire colors and functions but now need help figuring out correctly which wires needs to be removed can anyone help me now?
Ok so far it seems c1 (red)80 pin I need to remove pin #'s 3 evap canister vent solenoid valve,14 a/c status,39 a/c clutch relay control,45 evap canister purge valve control, 47 a/c request signal,62 egr pintle position ground. I still ? pin #'s 11 vtd fuel enable, 24 sensor ground jumper,32 pnp switch signal (what is this),75 left and right fuel tank sensor ground. please help a guy out I am trying to figure this wiring out while learning also. If I have missed anything will you please let me know? Thanks in advance Brandon
Oh by the way this is going in a 72 Chevelle with ls6 intake among other engine mods.
Lots of guys have done them. The best way to do it is to get a wiring diagram and mark up what you don't need. Then remove those wires from the PCM and work back to the plugs. From the plug work back to the harness removing the power and grounds, that went to those plugs. If you need wiring fiagrams email me through the forum, and i'll send them to you. i should have them
