Help with LS2 P/S Pulley
Old 05-11-2009, 06:02 PM
mmaliszewski's Avatar
Default Help with LS2 P/S Pulley
Hello Everyone, new guy here. I need some help finding a smaller diameter power steering pulley, 5" or smaller for a 2005 LS2 I pulled from a Corvette. Any help would be greatly appreciated.
Thanks,
Matt
Old 05-11-2009, 11:23 PM
Kevin Winstead's Avatar
I think this can be rectified with a smaller, GM 5-inch-diameter pulley (PN 10166335). This smaller pulley has a 0.750-inch shaft diameter. This is what I did on my 6.0L. Good Luck.
Old 05-12-2009, 01:34 AM
dsrour's Avatar
Is the shaft size different from an LS1 pump?
thanks
Old 05-12-2009, 06:59 AM
Thanks for the quick responses. Looks like that pully would not work as the water pump has around a .62 diameter shaft. It is out of a 2005 Corvette which I believe has a differnt water pump than the other motors.
Does anyone know if the pumps are the same as far as how they mount? If so I could buy the pump with the larger diameter shaft and then use the 5" pulley. . .
