Using a 99-02 truck ecm...will the fans work?
Old 05-11-2009, 10:59 PM
3.1EyeCandy's Avatar
Default Using a 99-02 truck ecm...will the fans work?
The shop doing the tune on my GTA (among other things) found out that the ecm/pcm I bought used (supposed to be for a 01 Trans Am) was actually a 99-02 truck ecm. They got the car to run, but neither fan would turn on. The harness is from Speartech and has the fan outputs on it run to a set of relays. I was just thinking that the trucks didn't use electric fans, right? Would this cause my wired in fans not to work?
Also - can the f-body OS be flashed on one of these pcms?
Thanks
Old 05-12-2009, 12:05 AM
sawzall wielding director
G-Body's Avatar
The fans will work, they will have to be enabled in the tune though. And yes the f-body OS can be flashed onto that PCM
