cylendar 1 firing only
Old 05-24-2009, 08:15 PM
lscustom's Avatar
Default cylendar 1 firing only
03 5.3 custom harness stock computer re-mapped by some loser missing in action, blue and green connections on ECM, 4L60E trans all stuffed into a 40 chevy truck....it just won't fire. I have cyl number one firinig only, its the only wet plug and I have 56 lbs pressure in the rails.......something I am missing? any help would be greatly appreciated. Thanks!!!!
Old 05-24-2009, 09:21 PM
ls1nova71's Avatar
Has the motor been sitting a while? Injectors might be stuck.
Old 05-24-2009, 09:31 PM
jomomma's Avatar
definetly check for clogged injector first. the wiring to the injector isnt hard to chase either.
Old 05-24-2009, 10:01 PM
lscustom's Avatar
Default still #1 cyl only one firing
did investigating on the web....hearing crank position sensor so I replaced that....and still #1 cyl is the only one firing
Quick Reply: cylendar 1 firing only
