what kind of master cylinder bracket for 1965 malibu?
im hoping to get a little help from you guys. im wanting to install the master slave cylinder into my 1965 malibu. has anyone done this in a car like mine? I s there a certain bracket that I can make? I would appreciate any input.
Not sure what you're actually asking... there's no "master slave cylinder" it's either the master or the slave? Are you talking about the clutch (likely) or braking system?
i didnt want to say master cylinder because it would likely confuse someone. i guess i should have put it master/slave cylinder. anyway, im looking to find out if anyone on here has already mounted the master cylinder(clutch) to the firewall on a car like mine. or if there is someone out there that sells a bracket to properly locate it. im trying to figure out how to connect from my clutch pedal to the master.
You can find the template on the S&P web site.. I beleive that ATS designed and markets the bracket which will work on most F, X and A body cars and will use the 4th Gen Master along with the slave...
It can be fab'd up from 1/4" maybe 5/16" steel. I just took a few hours of my time and just some cutting wheels, grinder and a drill...
