Are the holes in the block for 5.3 iron & Ls1 the same?
Old 06-11-2009, 07:31 PM
91notch's Avatar
Default Are the holes in the block for 5.3 iron & Ls1 the same?
I am going to swap a 5.3 turbo into a 91 coupe mustang & wanted to go the 4.6 k and modded 4.6 mounts route, but i thought I remembered reading that the mount holes on an iron 5.3 and the aluminum Ls1 were different. Anybody ran into this? Can you do a similar mod to the factory mount and make it work on a 5.3? If I need to search just put me in my place, but i searched a couple ways, & found no definitive answer.
Old 06-11-2009, 07:47 PM
jhubbs's Avatar
As far as I know, there are only two bolt holes that are different between an LS1 and a 5.3l, and both of those are for the alternator mount. The LS1 has an alternator mounting boss the 5.3 doesn't have, and the LS1 has a hole tapped for the alternator bracket that is untapped on the 5.3.
Old 06-11-2009, 09:13 PM
91notch's Avatar
heres a better way to ask this question: Will a 5.3 bolt into a ls1 camaro without changing mounts?
Old 06-11-2009, 09:37 PM
89notch5.3's Avatar
The ls1 block has an extra hole by the motor mount holes for a ground, iron blocks dont. I made a 1/4" plate to adapt a 4.6 mount to the block.
Old 06-11-2009, 10:25 PM
91notch's Avatar
so basically the same elongate the mount tab on the 4.6 mount and its a bolt on affair no dofferent than an ls1?
Old 06-11-2009, 10:44 PM
sawzall wielding director
G-Body's Avatar
The motor mount bolt holes/pattern is the same for the 4.8, 5.3, 5.7, 6.0, and 6.2`s.
Old 06-11-2009, 10:48 PM
89notch5.3's Avatar
5.3 blocks dont have a hole for the rear tab on a 4.6 mounts. I put a plate between the block and mount similar to the sbc adapter plates.
Old 08-23-2013, 05:50 PM
TipsyMcStagger's Avatar
Is this statement accurate?
The first two posts in this thread would seem to suggest otherwise?
Tipsy
Old 08-23-2013, 07:42 PM
fox12303's Avatar
To my knowledge the motor mounting pads for gen3/4 are all basically the same, 4-bolt holes. Not sure about LS7/9 but they are LS blocks so i'd bet they are the same too. Accessory mounting holes are slightly different as mentioned in previous posts.
Old 08-23-2013, 10:05 PM
usdmholden's Avatar
The four motor mount holes on the LS motors are the same. They are four holes towards the front of the engine, on a square pattern of 78mm x 112mm.
The 4.6L motor mount leg which gets extended is not a motor mount boss, it is a block ground hole, which is coincidentally drilled and tapped for the same thread on the aluminum blocks. The iron blocks have this hole drilled and tapped, this is why the adapter plates were invented. Also the hole spacing on the mod motor mounts is not 78mm in the vertical, you have to elongate one of the holes.
Old 08-24-2013, 05:37 AM
Okay, but in this post, it appears the OP is indicating that the lower left hole (the one covered by his hand) does not align ("they line up in the 2 holes pictured and the one bottom hole." What am I missing? Is that lower left hole (in the mount) what you're saying needs to be elongated?
Tipsy
Old 08-24-2013, 08:16 AM
brewster240's Avatar
Originally Posted by fox12303
Bell housing bolt holes do differ from the iron block and aluminum so check that they match the tranny you are using. Accessory mounting holes are slightly different as mentioned in previous posts.
no they dont. only the front wheel drive block is different.
Old 08-24-2013, 04:06 PM
the iron and aluminum blocks have the same trans bolt pattern.
same bolt hole added, same bolt hole missing, when compared to a gen1 or gen2 small block.
Old 08-30-2013, 09:06 AM
usdmholden's Avatar
Tipsy
Honestly, I hate to say this, but search the forum. That issue has been known about with the AJE mounts for years. I can't explain to you why AJE makes what I consider to be stupid decisions.
The motor mount holes on an LS are 78mm vertical x 112mm horizontal. Mod motor mounts (which are not AJE mounts) are not on 78mm vertical centers, but they are so close that one hole can be slotted to reach the 78mm vertical center.
LS motor mount bosses are the same regardless of gen3 / gen4. I don't know anything about gen5.
Old 08-30-2013, 09:43 AM
Just trying to get accurate info. Believe me, I search. There is a ton on inaccurate and conflicting info on this (and every) forum. I'm just trying to get educated.
Thanks for clearing that up.
Tipsy
Quick Reply: Are the holes in the block for 5.3 iron & Ls1 the same?
