Cooling Fans and relays?
Old 06-30-2009, 08:53 PM
xyster's Avatar
Default Cooling Fans and relays?
I bought a 16" s blade fan 2500 cfm and i have a bosch relay wired up but the fan is a 17 amp and im not sure what the relay is rated at. Do I need to find one that can handle the 17 amp fan. I know the PCM triggers it with ground and i can check it all out by grounding the relay to kick on the fan. just need to know if I should find a specific relay.
Old 06-30-2009, 11:41 PM
sawzall wielding director
G-Body's Avatar
Most bosch relays are labeled right on the outside with the amperage that they will handle, so check yours out before you buy a new one.
