Will truck injectors work in an LS1 intake?
Just curious if this will work or not. I would like to run an LS1 intake, but I have a truck harness. So I was wondering if the truck injectors will work with the LS1 intake and rails? I doubt it, but thought I would ask.
They will fit if you remove a bit of plastic from the injector, but you will either have to modify the LS1 rail or use the truck rail to make the setup work. The ls1 rail is farther away from the manifold since the injectors are longer than the truck style injectors. If you are using the intake for clearance, the truck rail won't work since its bigger than the intake was to begin with. I suppose modifying the LS1 rail wouldn't be too hard, but in my case it was easier to spend 35 bucks and just use a set of LS1 injectors.
