Help will not run
Help will not run
I am just finishing my LS6 conversion into a Jeep TJ. Last weekend I fired the motor for a quick 30 seconds and she fired right up. Saturday I finished all the plumbing and tried to start it so we could check oil pressure etc and let it run for a bit.
It started right up ran for 30 seconds or so but not more than a min. The oil pressure was starting to climb nicely then it shut down and will not re fire.
There is 60 PSI fuel pressure
Starter spins motor over.
Definitely fuel in the cyl's can smell when plugs are pulled
Getting a back fire through the intake
Does any one have Ideas? seems like a timing issue so I am thinking CPS but not to sure. The Timing was set dot to dot and the motor spins freely. Im stumped and in a rush to finish this off. PLease help
Vats is bypassed with a box from painless, came with my painless harness. I will check the connections again
No codes and the grounds all check out to be good.
Im stumped. I am running a stock program for now as i am still in the stage of getting it running.
