1970 elcamino lq4 swap ?s
Old 08-24-2009, 10:15 AM
70cartruck's Avatar
Question 1970 elcamino lq4 swap ?s
just bought a 05 6.0 out an 2500 suburban......
i know its drive by wire tb so how do i swap over to the old cable tb.....does it involve something with the engines ecu.......
where is the best place to buy the flywheel spacer i will need to run this on a th350....will the flywheel work off the motor or will i need a different one...
if i go with a walbro 255 pump and the corvette fuel reg....what part number walbro pump will i need....(theres tons to choose from....) will any work.....
and sorry but one more question.....for those of you who have used aftermarket long tubes for the gm a body swap.....will any of those let you run factory power steering....or is the steering box in the way.......?
sorry for all the questions....i have read alot on here just tryin to get the specifics now....tryin to start ordering parts....
thanks
Old 08-24-2009, 10:42 AM
71 chevelle's Avatar
check the stickys look for any a body set up.
Old 08-24-2009, 03:40 PM
70cartruck's Avatar
i have been reading on the stickys just wanted some specific answers....sorry
Old 08-24-2009, 06:18 PM
13 Second Truck Club
726.0chevelle's Avatar
i would just sell the harness here online and buy a custom harness for the cable tb i think the 6.0 already has the spacer on it, and i beleive the flywheel will work just might need to elongate the holes a hair, just use the regular 255lph fuel pumps if your fuel rails have a return on them you will not need to buy a regulator
Quick Reply: 1970 elcamino lq4 swap ?s
