A few conversion wiring questions!
I searched but could not find the answers
Does the PCM control whether the AC Relay trigger has a ground, or does it give the trigger 12v?
Does the PCM Speedometer OUTPUT put out a pulse for aftermarket electric speedometers to pick up? That would make speedometer alterations a breeze.
Hmmmmmmm..... Jegs happens to give ZERO information on this, and google is as about as helpful
http://www.jegs.com/i/VDO/918/437153/10002/-1?CT=999
http://www.egauges.com/vdo_mult.asp?...Vision&Units=E
Dear Sir, Thank you for your interest in Jegs and your question today. The VDO 918-437153 is a very versatile programmable and will work with hall effect or inductive senders. It will work with your 4000ppm sender, no problem.
The above item is in-stock and will ship same day if ordered before 9PM EST. You may place your order 24/7 at www.jegs.com or by calling 800-345-4545.
We look forward to your order and please let me know if I can assist further.
Eric Smith
Mail-Order Supervisor
800-345-4545
ext # 866
Eric.Smith@jegs.com
Eric Smith
800-345-4545
ext # 866
Eric.Smith@jegs.com
