Neutral/safety switch signal wire for 4l60 question
I bought a standalone wiring harness for my 98 ls1 with 4l60e. Going into a 69 chevelle. Not quite sure how to wire up the signal wire for the neutral safety switch located in my center console on the shifter. Anybody? Im sure its somethin easy, just want to get it right the first time.
The wire needs to be grounded in park and neutral. The problem is it can't be done with a stock 69 Chevelle neutral safety switch. At least not when using the original switch for neutral safety and back up lights. You'll have to add another switch, or use some micro switches to send a ground when it's in park and neutral.
