For Carb guys
im running the gm colbalt 2 bar sensor,,since im boosting... right now temperarly i have it hook to the vacum port of the carb, in a vacum hose. but i will be putting it in the tapped port in the manifold.. just put it in a vucum hose or somthing..
Location: Your girl's back door giving her the long stroke while you're at work
Got mine in hooked into the port on the side of the intake and held down using the driver rear intake bolt. It's a factory GM F-Body MAP
