6.0 in a 68 Camaro
Old 10-26-2009, 07:27 PM
50adrod's Avatar
Default 6.0 in a 68 Camaro
I need ideas and info. swaping a 6.0 LS based motor in a 68 camaro, I currently have a 6.0 truck motor complete with all accesories and ECM. the goal is 600-650 hp if possible. a supercharger is not out of the question or possibly stroking it. I do not want nitrous. will the truck accessories work in the camoro? I need to retain A/C also. I realize it will need heads, cam and blower or heads cam and stroker to reach the 600-650 hp range. what is my best option? the trans is a built 700R with manual valve body. thanks
Old 10-26-2009, 07:30 PM
NemeSS's Avatar
your trans will work with few mods and correct parts.
the truck acc. may not clear your hood, depends on mounts used.
Old 10-27-2009, 11:52 AM
68 RS Convertible's Avatar
I am running a cowl induction hood and the truck accessories and everything clears my hood.
Old 10-27-2009, 12:35 PM
50adrod's Avatar
thanks for the pic are you using A/C ? do you think it would clear the crossmember in the stock truck location?
Old 10-28-2009, 07:38 PM
No, I don't have A/C, I just drop the top! From everything I've read you have to notch the frame to get the A/C to fit.
Old 10-28-2009, 10:37 PM
KJ@DHRC's Avatar
You will have to notch the frame a bit to get the A/c to clear, but not much.
You will need a few other pieces to complete this project as in: motor mount adapter plates, headers, oh and we can help you with a custom harness that will fit your motor in your car vs making one work out of a truck if you decide to go that way. Our harness builder lets you decide where you want the PCM to be located in your car!!
Quick Reply: 6.0 in a 68 Camaro
