drive by wire????
LS1Tech Sponsor
If you have the donor car, use the DBW from it. Keep the throttle body, pedal and teac module (if it uses one) together. What year LS2 (24X OR 58X)?
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Dbw
So it is a 24x crank sensor. You can do a few things. you could keep the E40PCM or go to a 411 and use a 2001 corvette TAC Module and Throttle Body. I would probably stick with the E40 but I am not too sure how much aftermarket support you will get with that. Any comments out there?
__________________
Ebay Store
Ebay Store
LS1Tech Sponsor
Any DBW will work as long as the Throttle body, TAC Module (non E38/E40/E67 applications), pedal and tune match. 06 GTO used a E67 not an E40. Once again I am not sure how much aftermarket support you will get with the E67.
__________________
Ebay Store
Ebay Store
