6.0 into a 94 Camaro
Old 11-17-2009, 08:29 AM
Loudpipe's Avatar
Default 6.0 into a 94 Camaro
Alright guys I'm going to upgrade my LT to a LS. I have a 6.0 bottom end and an ls1 k-member. My plan is to run a carb and distributor. I guess I just need someone to tell me what it will take to make it run. Or if getting a harnness and pcm and going injected would be easier. All help is greatly appreciated!
Old 11-17-2009, 10:42 AM
the_merv's Avatar
Injected is actually pretty easy to do.
Check this out..
https://ls1tech.com/forums/conversio...to-95-z28.html
Old 11-17-2009, 10:59 PM
customshop's Avatar
FI in the only way to go.Painless performance,or Spear Tech can hook you up with all your needs.
Old 11-18-2009, 08:53 AM
Loudpipe's Avatar
Thanks from both of you guys. Im trying to keep this project on a budget. As odd as that sounds.lol Merv thanks for all the info. Has anyone had any luck with a carb and distributor? What does it exactly take to make it run?
Quick Reply: 6.0 into a 94 Camaro
