stock cluster no pcm
Old 01-12-2010, 12:55 PM
cjg454ss's Avatar
Default stock cluster no pcm
anyone know if this is possible. make the stock 2002 gauge cluster work without the stock pcm. i run bs3 and no longer have the stock pcm or wiring harness. i jus twant the basics, speedo, temps, oil pressure, tach, fuel.
is it possibly, ive searched with no luck
Old 01-12-2010, 07:53 PM
poconojoe's Avatar
It looks like everything comes from the PCM except the oil pressure and the speedo, heres the pin out for the cluster connector
A1-A2
Not Used
A3
PNK
39
Ignition 1 Voltage
A4
Not Used
A5
TAN/WHT
33
Brake Warning Indicator Control
A6-A7
Not Used
A8
BRN/WHT
419
MIL Control
A9
Not Used
A10
ORN
640
Battery Positive Voltage
A11
Not Used
A12
LT BLU
14
Left Turn Signal Lamps Supply Voltage
A12
LT BLU/WHT
1414
Left Front Turn Signal Switch Signal
A13
PPL/WHT
237
Instrument Panel Lamp Control
A14-A16
Not Used
A17
LT GRN
11
Headlamp High Beam Supply Voltage
B1
BRN
9
Park Lamp Supply Voltage
B2
Not Used
B3
GRY
728
Security Indicator Control
B4
Not Used
B5
PPL/WHT
1035
Starter Relay Coil Supply Voltage
B6
GRY
1036
IPC Class 2 Serial Data
B7
ORN/BLK
737
Trunk Lamp Control
B8
DK GRN/WHT
817
VSS Signal
B9
GRY
8
Instrument Panel Lamp Supply Voltage - 1
B10
DK BLU
15
Right Turn Signal Lamps Supply Voltage - Europe, Japan
B10
DK BLU/WHT
1415
Right Front Turn Signal Switch Signal - Domestic, Gulf
B11
BLK
650
Ground
B12-B22
Not Used
B14
TAN
31
Oil Pressure Indicator Control
B15
BLK
650
Ground
B16-B17
Not Used
