need some 5.3 help
need some 5.3 help
im putting a 5.3 in my 67 camaro andgotta question. what do i do about the pcv system. i have the pasenger side hooked up to the intake where it should but what about the driver side back of the valve cover where the grommet is? do i hook it up to a vacuum source too? and how?
If you are using the truck intake there is a port on the top center of the intake that a hose connects the valve cover to. If you are using a different intake just hook the left valve cover to intake vacuum.
