1974 chevelle 5.3 swap fuel system and accesories help
ive got a '74 chevelle that im swapping a '99 5.3 into and am looking to do it somewhat cheaply until i can afford to bore it out to be a 5.7, and suggestions or ideas on the best way to go about it would be awsome, im mostly worried about the fuel system as the car is carborated right now. thanx in advance for help.
Some of the earlier Chevelle guys are using a 96 Impala ( I am ballpark on the year) poly gastank. From what people are saying. $75.00 at the junk yard. Simply swap out the intank pump and mount. Then run a Corvette fuel filter/pressure regulator. You can run hard line or something like Summit pushlock fuel hose.
Try doing a search for more accurate information. I know my info is very basic at best, but it might lead you in the right direction.
