Trouble with fittings.
What fittings do ineed to make my 2000 auto 4l60e ls1 work with my 71 camaro.
I have a c-5 fuel pump walbro 255lph in line fuel pump. And I need to find out what sixe the power steering pump fitting is espescialy and what size the inletis on the intake etc.
Eaton/Aero-Quip sells the power-steering fittings that thread into your pump, and into your steering box. One side is high pressure(supply from the pump) & the other is a low pressure return to the P.S. reservoir. Look fora local hydraulic hose/industrial hose shop in your area that sells Eaton/Aero-Quip...and they will have everything you need. If they don't have it on the shelf, they can get it in by the next day for you.
