Power Steering Pump outputs - GTO, F-body, Corvette, CTS-V, Truck etc!
Old 06-17-2011, 08:40 PM
ponjohn's Avatar
I had no idea the pressures used were that high.
Good stuff.
Old 08-11-2011, 04:33 PM
GIGAPUNK's Avatar
Can a corvette pump be used on an f-body mount, and mantian the f-body offset?
Old 09-30-2011, 09:45 PM
tnewton's Avatar
Take a look at the pump, sometimes they'll interchange. I've got a lq4 with a dodge Dakota pump in the gm res, same casting...
Old 10-02-2011, 09:34 AM
Old Buzzard's Avatar
Lightbulb Borgeson has..
Originally Posted by lq4240sx
Having the same issues. I blew out the stock rack because i didnt know the pump over flowed the rack. I got a new rack and added a restrictor in the line the outlet on the restrictor is 50% smaller then the original hole. After driving it around for a week the new rack is blown. I'm thinking about trimming this spring to relieve the pressure.
the solution to the rack problem..A kit for $17.00.
I got involved in this same problem w/ a 500 box on my 55 Chevy. I have the 05 Hummer ,[6.0] pump feeding it. Waaaay too touchy.
A call to Borgeson and a kit from Summit has been installed. [I used 3 shims to drop the psi to approx 1000psi.
The kit has 5 shims, a tool to hold the cartridge, o'ring, and instructions.
http://www.borgeson.com/xcart/catalo...p-1-c-133.html
He also said they use LUCAS p/s leak stop oil in the pumps. Makes them much smoother and alot less noisy.
Haven't driven it yet..Waiting on inj plugs.
Nice thing about the shims, it doesn't ruin the spring if you cut it too short!
The following users liked this post:
Stu Cool (08-26-2019)
Old 10-10-2011, 01:38 PM
kalech's Avatar
The Lincoln LS I'm swaping into has rather high PSI for its relief valve:
Flow 9.00 ± 0.75 liter/min (2.4 ± 0.2 gpm) @ 1,000 kPa (145 psi) @ 1,500 rpm
Minimum capacity 4.0 liter/min (1.0 gpm) @ 4,999 kPa (725 psi) @ 500 rpm
Relief pressure 11,197-11,997 kPa (1,624-1,740 psi)
Either of the CTS-V pumps seem to be ideal to match it (the later model with a control valve), but I was wondering what happens if I just go with the Fbody pump with a control valve (my LS1 is out of an fbody)? That will mean the pressure relief will be much lower than the factory specs.
Old 10-10-2011, 03:47 PM
Bob H's Avatar
One big key is the depth of the mount for the PS pulley - i.e. is it the CTS-V/G8/Corvette depth, the F-body/GTO depth or the Truck depth?
You have the F-Body accessories, so the F-body pump would likely be your best match. The CTS-V won't mount up and work w/o some significant fabrication or a bracket I don't know about.
-Bob
Old 10-11-2011, 03:50 PM
kalech's Avatar
Thanks Bob, I assumed there there were brackets available for it -- maybe not. So the lower pressure relief won't affect steering too much? The CTS and Lincoln LS both have high pressure and both are "luxury" cars, so if it just makes it require a little more force to turn, I have no problem with that.
Old 10-11-2011, 11:24 PM
BBPanel's Avatar
This is an excellent thread. Question now is what source do you use to determine the requirements of one's rack or steering box? In my case I have an LS1 pump and a 86 T-Bird rack. I put a flow restrictor on it but I'm starting to think I need to determine pressure requirements. Thanks. -Bob
Old 10-13-2011, 03:08 PM
kalech's Avatar
Alldata probably should have it (I don't have access to it, I found my specs googling around).
Here's a pump for an 86 thunderbird:
http://www.summitracing.com/parts/AAZ-20-6248F/
From there, you might be able to call the manufacturer and ask what the specific specifications are. You might be able to just call Summit and see if they know.
Also, it looks like this is same product, so that means most likely the racks are the same (I know the mustang and thunderbird share the same platform):
http://www.autopartswarehouse.com/de...A1206248F.html
So you might have better luck finding the specs for a mustang pump.
Good luck.
Old 10-13-2011, 11:56 PM
BBPanel's Avatar
Thanks I'll take a look.
Old 10-25-2011, 06:27 PM
chpmnsws6's Avatar
Does anyone know where the pressure relief spring on the CTS-V pumps are? Mines off an 04-05 and in a little 90 Miata. Needless to say, the steering is VERY light. Needs firmed up a hair.
Old 10-25-2011, 07:31 PM
  #32
S10xGN's Avatar
Up inside the pump, under the HP fitting...
Old 10-25-2011, 07:47 PM
  #33
chpmnsws6's Avatar
So the pump needs split? How much of the spring should I cut off? Sorry, I feel very naive and don't want to waste a good pump on a science experiment.
Old 10-26-2011, 08:35 PM
  #34
S10xGN's Avatar
No, I believe the pressure line fitting unscrews out of the body and the the relief valve is under it.
Old 10-28-2011, 08:41 PM
  #35
chpmnsws6's Avatar
Thanks! Guess its time for me to get my hands oily
Old 01-24-2012, 07:06 PM
  #36
Squeezer's Avatar
Default 5.3 with T-Bird Rack
Will the Power Steering Pump from my '05 5.3 be in the range of the correct pressure and flow for the Thunderbird rack n pinion on my TCI Pro Touring front clip?
Old 01-24-2012, 10:09 PM
  #37
S10xGN's Avatar
Unlikely, Glenn. I found out real quick it didn't work on my setup when I tried bleeding the system, a slight nudge of the steering wheel ended up with violent lock to lock jerking. I'd stick the DSE fitting in the pump before putting it in the car if possible, it's a bit harder doing it after final assembly.
Old 01-24-2012, 11:06 PM
  #38
Squeezer's Avatar
Thank you Russ for the insight,
Old 01-25-2012, 06:17 AM
  #39
kwhizz's Avatar
A LS2 power steering pump from a 2004-06 GTO matches the T-Bird rack almost perfectly 2 GPM flow and 1100 PSI..........I had a Mustang II rack and the car was way Twitchy........swaped a Stock T-Bird rack and everything is now "Happy"......
Ken
Old 09-26-2013, 03:47 PM
  #40
rockytopper's Avatar
Great info! Going to try and match a lsx power steering pump to an original 1955 chevy power assist unit. Said to require 750 to 850 psi max.
Quick Reply: Power Steering Pump outputs - GTO, F-body, Corvette, CTS-V, Truck etc!
