Anyone know the Part# for the terminals in the pcm connector.
That link no longer worked for me;
Found the connector info that lists the pin though.
http://www.eficonnection.com/eficonn...spx?ItemId=286
EDIT; Wait, which is it? The .5-.35 or the .8?
They're an amazingly reasonable ~25-36 cents each and it saves having to try and "unwrap" the connector from the wire of each and every pin I pull from a JY car? I want to make a completely new harness, not patch into one. I have a patched harness already. Just my $.02
I agree though, it would probably be cheaper if you're starting from scratch. However, then you don't get the nicety of putting things where you want/routing them where you want.
Oddly enough Pocket, I was going to PM you asking if you knew the pt# but figured I'd search first. Guess I should have just pm'd ya!
