04 GTO fan wiring diagram needed
Can someone post the fan wiring diagram for the 04 GTO. I found the 05 and 06 fan wiring diagrams, but can not find the 04 and they are different.
Thanks
AJW
Thanks
AJW
I have one off of alldata but I don't think I can post it. You can get a coupon code off google and it will cost less than $20. The high speed relay comes off of the PCM and the low speed comes from a BCM connector. If you are doing a swap that doesn't require a BCM the PCM will have to be flashed to enable one of the pins to run the low speed relay.
Thanks guys. Arthropraxis sent it to me in a PM. I had Speartech activate the other pin and add the wire for me. Hopefully I will be able to get them to work now.
Andy
Andy
