LSX swap in 1996 Impala SS
Old 06-07-2010, 08:56 AM
Stangkilr's Avatar
Default LSX swap in 1996 Impala SS
Here is what I have going so far.
-LS6 crate motor/ gm hot cam
-FLT level 4 4l60e
-Yank SS3600
-Custom harness
-f-body pacesetter headers
-CTS-V front accessory's
I have a couple questions:
1. How to run and what to use for power steering lines
2. Will the stock fuel pump and system work as long a I run a return off the rails?
Old 06-07-2010, 09:34 AM
aknovaman's Avatar
Get a Walbro intank 255 fuel pump to replace the older pump from Jegs or Summit for $99..
Old 06-07-2010, 10:17 AM
383lt1impala's Avatar
Agreed on the walbro. And u can have a local hose/fitting shop make the steering lines for u.
Old 06-07-2010, 10:46 AM
Stangkilr's Avatar
Thanks for the input guys! So is the pump the only thing I have to do?
This is for a friend of mine, im just helping him out. Never done a swap before.
Old 06-07-2010, 12:57 PM
The stock pump is weak. That's cheap insurance u don't want it to run lean.
Old 06-07-2010, 02:33 PM
Stangkilr's Avatar
Got it! Thank you sir. Anything else I should know?
Old 06-08-2010, 08:13 PM
not that i can think of if u have problems theres ALOT of good info in the performance section of the impalassforum.com
Quick Reply: LSX swap in 1996 Impala SS
