HELP.....looking for g-body oilpan that clears co
Old 06-29-2010, 11:13 PM
86 g-body's Avatar
Default HELP.....looking for g-body oilpan that clears co
I need an oilpan and motormounts that will not hang below the frame for my 5.3 in my cutlass.Also I want to use f-body front acc on stock mounts and not loose my a/c on firewall .Not wanting to do any frame mods if I can get around it.She has an airride setup and dam near lays the frame on the ground when lowered.so I need an oil pan that will suit my needs.....try calling the guys at retro and posting on there site with no luck on the pan that they built.so I'm turning to the fellas on here. Thanks in advance for advice....
Old 06-29-2010, 11:44 PM
2Aspire's Avatar
They are up for sale on fleabay..
http://cgi.ebay.com/ebaymotors/LHX-C...QQcmdZViewItem
Old 06-30-2010, 09:20 AM
MonteHawk's Avatar
Default G body oil pan
I saw the Holley 86 El Camino build on Power Tour and was really impressed with what they did. Here is a link to thier site, sadly not all of the details are posted like exactly which pan they used. But I do like thier motor mount plates and use of the F Body Motorsports AC Compressor bracket.
Old 06-30-2010, 09:27 AM
Marcello7x's Avatar
BATWING pan work? They're cheap too!
Old 06-30-2010, 03:03 PM
Nashty's Avatar
I used the stock 5.3 pan and laid the car on it's frame (also airbagged). Took a piece of 1" square tube (acting as a 1" spacer from the ground) and marked around perimeter of the pan. Cut if off there and welded in a piece of 1/4" alum. Measured for new pickup depth and cut / welded it. Noted how much pan I cut off and removed that much from the stock dipstick. I lost about a quart but the truck pan is 6 quarts already I believe.
Quick Reply: HELP.....looking for g-body oilpan that clears co
