4l60e transmissions, which years are correct for genIII engines?
Old 07-28-2010, 10:29 PM
chevyboy91188's Avatar
Default 4l60e transmissions, which years are correct for genIII engines?
ok so yet another question, what year 4l60e transmissions are the correct ones to use when doing a genIII swap so that the ecm for the engine can also control the transmission without any mods?
thanks
nic
Old 07-29-2010, 11:19 AM
LS1Tech Sponsor
psiconversion's Avatar
95-newer 4L60Es were Pulse Width Modulated(PWM) so they will work with an LS PCM. However, from a physical standpoint, 98-newer camaro/firebird and 99-newer trucks will work without a hub spacer and special flywheel. All older Transmissions will require the spacer and flywheel (or modified stock flywheel).
Jon
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 07-29-2010, 08:52 PM
Ok thank you very much that helps alot
Quick Reply: 4l60e transmissions, which years are correct for genIII engines?
