Mustang guys running stock EFI cable, help!
Old 11-12-2010, 09:28 AM
dville_gt's Avatar
Default Mustang guys running stock EFI cable, help!
I have to crack the throttle blade to hook up the cable, like the mount is not the correct distance from the t/b so it has to pull slightly to be hooked up. I assume once I get this thing started it is going to be a problem as I am fairly certain it will not like having the throttle slightly cracked all the time.
Did you guys have to bend the throttle bracket (this is on a truck intake btw).
Any other ideas?
Old 11-12-2010, 11:49 AM
bad6as's Avatar
i dont have any good pics but maybe you get the idea. it bolts to the intake.
Quick Reply: Mustang guys running stock EFI cable, help!
