Wiring Harness Question
I was working on stripping the unneeded wires out of my harness and i kept running into these things.
Is this a fusible link?
What does it do?
Do i need to keep them or can i cut them out?
Thanks in advance
What does it do?
Thanks in advance
Thats a common splice. When building harnesses, I cut them out. Some you'll delete when removing unnecessary circuits, most will be spliced back together with a heavier gauge wire grounding to the engine. Its just easier to split them up, do the changes and put them back together in the end
Thanks for the advice
