MIL - Check engine light issue
Old 12-16-2010, 10:44 AM
brianjw4's Avatar
Default MIL - Check engine light issue
I can't seem to get the check engine light to work. I've got an led with the positive side wired to ignition and the negative side to the brown/white wire. The pcm is throwing a MIL circuit code. It's a 2000 f-body engine / harness.
Has anyone had this issue before? Maybe I'm missing something.
Old 12-16-2010, 10:54 AM
TomM's Avatar
Do you have the polarity on the LED correct, they only work one way.....check the LED and see if it's good, on a know power source...battery etc..
T,
Old 12-16-2010, 11:08 AM
brianjw4's Avatar
Yeah, I tested the light. Works fine with when grounding to the chassis and using ignition +.
Old 12-16-2010, 02:24 PM
gofastwclass's Avatar
An LED doesn't draw enough current to work properly. You need to use a regular lamp or a resistor with the LED. Since I'm at work I can't tell you what size resistor you will need but I think I have a link saved at home with all kinds of goofy info like that.
Old 12-16-2010, 02:29 PM
brianjw4's Avatar
hmmm, did put a resistor on the led. Will have to try hooking up a regular bulb to the pcm ground and see if it works.
Old 12-16-2010, 02:37 PM
brianjw4's Avatar
found the problem - previous owner of the harness cut the wire at the pcm - fixed and it works now. Funny, the harness was advertised as with "no cuts" and it had this and the egr pigtail cut off.
thanks for the help guys
