Anyone with a LQ4 swap dyno the car stock
Old 01-07-2011, 10:12 PM
Bobby G's Avatar
Default Anyone with a LQ4 swap dyno the car stock
Anyone dyno their car stock, what gears and tranny . anyone have track times. I am putting a LQ4/4L80e swap in a 1980 T/A
and am curious about dyno numbers and track times. Thanx
Old 01-08-2011, 10:23 AM
Bobby G's Avatar
no one has dynoes there lq4 or taken it to the track?
Old 01-08-2011, 08:39 PM
Luke Skyjacker's Avatar
look up billyflantos
Old 01-11-2011, 07:57 PM
tsnow678's Avatar
I will get you some numbers and a dyno sheet as soon as mine hits the road. It might be a little while though. Do you have a dyno sheet on your build?
Old 01-12-2011, 07:43 AM
Bobby G's Avatar
No its all stock on a engine stand right now. I'm in NY right now the snow is coming down
Old 01-25-2011, 08:47 PM
LSXS15's Avatar
88 GMC s15, lq4 with iron heads, truck manifold. only mods are cold air intake and headers obviously. stock 700r4 3.42 gears. without going into closed loop put down 296 rwhp 386 lbft. pig rich tune also. on street tires and stock-slipping-3rd trans ran 13.55 @ 104, 2.05 60ft. obviously traction limited and lifted for 3rd to shift. theres a ton left in the tune let alone a rebuilt trans. should put down around 330 rwhp in stock form. look for high to mid 12s with some DRs and a properly setup suspension. add a cam or spray and youll be sitting 11s all day. stay with the 6.0, youll be much happier with bore size and strength of the iron block
Quick Reply: Anyone with a LQ4 swap dyno the car stock
