3rd gen ls oil pan
3rd gen ls oil pan
For all you who did a 3rd gen ls swap. I was trying to find out what oil pan would fit on a stock k member. I dont know if it would help but i have aftermarket mounts from hawks third gen.
We used the motor and transmission mounts from Spohn on the '89 my son and I did, fit right in using the 4th gen pan, it was tight, only 1/4" to 1/2" of clearance between the deep part of the pan and the k member.
The following users liked this post:
Larry mccaskill (02-03-2020)
Same here, Spohn mounts and the factory '01 Z28 oil pan. I relocated the brake line to free up a bit more clearance, apart from that it was a straight drop-in.
Not sure what you're trying to say w/ your sig, but if it's "I'm a complete idiot" you nailed it.
IF IT WASN'T FOR GM WAT KIND OF WORLD WE BE LIVING IN!
If your asking about my sig. 1. I was new to this forum and it was a spear of the moment ordeal. 2. Considering all the innovations and popularity gm has made its hard not to think of the world without it. It means just what it says dude.
