Any LSx 98+ S-10 turbo's out there? Looking for some pics of exhaust.
Well, I've scraped the swap in the thread in my sig. Got a 98' short bed regular cab 2wd s-10 as a replacement. Have a built LS-6 in the works. But for the moment, this Summer, I will be installing my LQ-4 to get the truck running and a new motor in. The 200k mile 2.2 is beat.
Once the built LS-6 goes in, I want to put a single front mount turbo on. But I cannot find any pre built hot side piping. Looking for trucks with any LSx engine with a front mounted turbo for referance. Looking to have the turbo on the passanger side up high. So the down pipe will be exiting on the correct side of the truck.
Once I start the swap this Summer, I will start a new thread with pics of the swap.
Thanks
Thanks
Thanks
Thanks
From the internet:
This one is on the driver's side: It's an S10 2-door blazer with a front mount. The owner purchased it from a shop in Kansas. It also has a C5 Vette instrument cluster.
http://www.s10forum.com/forum/f213/f...-truck-374387/
http://ss.lencolab.com/
I moved to the fox body for a few reasons, not wanting to build custom headers being one and and i wanted to do a fox body before i built the s10.
Basically its doable but not as easy of a build of a hotside as some other chassis's can be. And as far as i know no one builds hotside's specifically for the swap.
I've got a turbo Buick GN motor in my '96. I had to use a set of U-joints on the steering shaft for (V-6) header clearance, scallop the PASS floorboard just to fit a 3" downpipe, and cut the hell out of the radiator support to get the ('85 vette) radiator + A/C condenser + front-mount behind the grille. No room for the trans cooler, it's on the frame rail under the bed... Yup, S-10's have a pretty small engine bay!
Thanks for all the help everyone.
As far as the first pic, that is very similar to what I was thinking of building. But the following pics look like there was too much moved around.
I do not want to run anything in the wheel wells. As I will be running a 265 front tire and big brakes. I will be retaining the A/C system. Using Vette ront drive setup.
I will most likely be building the hot side one off. But I am hoping to be able to run a 3.5 inch down pipe. I cannot just do a dump under the front of the truck. It will be a street truck I will need to "pass inspection" and be livable on the street.
The battery will be in the bed. I might remote mount the ECU somewhere else other than on the coolant tank. The coolant tank will be mounted on the radiator support as a 1/2 gallon tank.
Sounds like alot. But I am looking for a challenge and some fabricating.
