Back fire befor startup?
Old 02-16-2011, 01:33 AM
sleepy_boy1's Avatar
Default Back fire befor startup?
Hi guys,
i completed a swap a ls1 few months ago, and everything ran fine, now i changed the wiring harness and the way it was set up and i get a few booms from the exhaust before start up.... so i put back the old wiring and still the same problem...
all coils work and spark plug and wire are new... i think my coils are firing in the wrong order... after a backfire from the exhaust the car starts up and runs fine....
thats why i think its the firing order of my coils or injectors.... problem is how do i check
i think i out wrong injectors on the wrong cylinders.... or wrong coil on wrong cylinder..
Old 02-17-2011, 12:00 PM
devlmaycry's Avatar
Might be able to hook up a scanner and run it through your injector firing sequence and what not. I'm sure one of the more knowledgeable guys will be able to help!
Old 02-17-2011, 03:12 PM
Prorac1's Avatar
Check the cam sensor. I have heard of problems like this occuring when the cam sensor is bad. Im by no means an expert, but its better than nothing, right, lol. Good luck, Eric L
Old 02-19-2011, 12:44 AM
ill check and let you know, can i check firing order with hp tuners?
Old 02-19-2011, 01:12 AM
you were right... it was the cam sensor
Old 02-19-2011, 01:31 AM
Prorac1's Avatar
Glad I could help. Eric L
Quick Reply: Back fire befor startup?
