6.0/5.3ls1 swap into 96 chevy Truck. worth it?
I have a 96 chevy silverado with the stock 5.7 vortec and a 5-speed manual transmission. Just looking for some thoughts on if this swap is worthwhile or if just hopping up the stock motor would be better/cheaper? I was leaning towards the 6.0 if I did do a swap. Thanks
The problem with your stock engine is that you cant get better injectors because it uses spider injectors, and i dont think you can get bigger ones. If you do too much you you would have to switch to some kind of intake that used regular injectors. I think it would be a cool truck to do the swap in. I have a 96 5.7 5 speed as well.
whatre those 5 speeds? t5? tko?
stock for stock theres more power and better mileage, if you wanna mod theres way better aftermarket and room for potential with an ls
you know you wanna
you know you wanna
Trans is a NV3500.
I've also got a 96 5.7 5 spd!
If the stock engine didn't run so darned good I'd jump into a 6.0 or 6.2 and a 6spd.
Mods
MPFI upgrade, V-max spacer, bad pcm tune, 1.6 rollers and bee hive spring.
Next will be long tubes, maybe a 411 pcm and better tune, electric fan-should add a bit of pep and free up some ponies....When I hit about 200K miles, an Ls engine will be put in.
Also, I've yet to read about a 4X4 with a 6 sp, and the NV 3500 is not the toughest trans.......so consider the cost of another better trans for the future, like a nv4500 with a steep 6:1 1st gear, or adapt your NV, or get an LS series NV.....or a TKO 500/600.....Mines 2wd so a 6er will be easy.
BTW the injectors are good for around 400 hp(helps to have the MPFI injector assembly), if you want more get a marine intake-than sky's the limit--the only problem with the old Vortec engines is cost/difficulty to mod and the minimal gains(marine intake=1000$ and fabbing to get it in). The Vortec intake and injectors will hit around 400 hp (400 hp in a 383 ci / or high winding 350=bad in a heavy truck IMHO) after thousands of dollars have been invested-than expect lousy MPG.
The Ls platform in stock 6.0 will be near 400 hp with headers and a tune...and get decent mpg in a 1500 series.
keep us posted, and if you do it, take detailed notes for me
Mods
I have a 96 Z71 that i want 2 do an lq4 swap to also. I have a 2001 K2500HD that my buddy wrecked so i have the the engine trans wiring.....everything. i just dont know what els i need 2 get in order to get started
