LSx in a Formula style car. Ever been done?
Old 03-17-2011, 12:08 AM
gta3uzi's Avatar
Default LSx in a Formula style car. Ever been done?
Has anybody ever put an LSx engine into a Formula Ford or similar chassis? That combination would run like a raped ape.
FF chassis, older ones at least, run about $3-4k and weigh about 700lbs w/o engine or transaxle iirc. There are always plenty for sale at apexspeed.com 's forums.
Old 03-17-2011, 12:14 AM
3.8redbird's Avatar
Do it and post the build
Old 03-17-2011, 10:40 AM
gta3uzi's Avatar
http://www.markkoch.net/canamMain.asp
Here's something similar. Looking at the pictures - The motor barely fits in the Ultima and it is twice as wide as a formula car. It does the same quarter mile with the big V8 as the ff's do with the 1.6l though.
Old 03-17-2011, 10:43 AM
TexasTechX1's Avatar
this. even a basic, lower HP built LS would be more than enough to have a hella fun ride!
Old 03-17-2011, 04:00 PM
jmarsa's Avatar
You're post is misleading...
Ultimas were designed to use a small block Chevy. In fact, the original designer was adamant that only a SBC should be used and argued with builders who suggested using LS engines.
How many people have every seen a FF, or any other formula car at the drag strip? It's a very odd comparison.
I don't see the advantage of a LS motor in a formula race car, it would need a dry sump system. But I agree with the OP that the strength to weight ratio sounds like fun.
Better would be this: http://dpcars.net/dp2/info.htm
--JMarsa
