pcm connector disassembly
I have an 04 LQ9 harness with the blue and green pcm connector. Does anybody have any suggestions about getting the lockring off of the screw that goes thru the middle of each connector? I've been working on it but I'm afraid I'm going to damage the connector. Thanks.
Greg, thanks for the reply, I was thinking it needed to be removed to be able to remove pins and wires I'm not going to need. Can you pull pins out without separating the aluminum piece from the pin holder?
