Green pin 59? Crank Voltage? Needed or not?
I'm making a stand alone harness taken from a 2006 LQ9 using a 04' GTO PCM (deleting DBW) It is going into an OLDER car...Truck pin-out shows Green 59 as Crank Voltage... GTO pin-out shows Green pin 59 Crank Voltage, is not used which tells me to delete this wire. Am I correct to delete this wire? Also, truck pin-out displays two vehicle speed signal wires Green 49, 50... GTO shows only Green 50 as a vehicle speed signal. I guess I delete wire at Green pin 49?? First timer here, any help is appreciated. Thanks!
