Transmission not shifting
5.3L / 4L60E in a 2002 Jeep TJ,
PSI Conversion harness
B&M Shifter
Took it out for my first little test drive this morning and found that the transmission wont shift if in DRIVE. It will shift between First and Second if i put it in Second gear but thats about it.
Any thoughts? VSS?
B&M Shifter
Any thoughts? VSS?
LS1Tech Sponsor
Is the check engine light hooked up and do you have the TCC wired to your brake switch correctly? Please give us a call to discuss. Thanks.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
