carbed Fox Mustang guys, in here
93 Reef Blue coupe, 4 banger, power NOTHING from the factory, not even the locks that most came with.
Engine & transmission are out and I've started removing the wiring. EEC harness and computer are gone, but there is a large harness that runs into the drivers side kick panel and the fuse box. The only things I plan on running are front and rear lights, AC, and maybe the radio.
What all can I safely remove to clean up the engine bay and save a coupla pounds?
Sway bar and the sway bar mounts on the frame if you didn't want to run a sway bar on the car. Also they make really nice lightweight bumper reinforcements that will replace the stock guts of the bumper.
If you wanted to get a little crazy pull up the carpet and remove all the sound deadening material
