1974 Camaro LS1 Engine Swap
Hey guys, first time user here. I have a 1974 camaro and a LS 1 w/4L60E. Also have a gmpp wiring harness, and fly by wire setup. How do I get this started?
Welcome.
Welcome. try using the SEARCH function at the top. You need to make sure the engine and ECM/harness use the same reluctor wheel. Most people have the best luck with 98-02 F-body oilpan setup and thesehttp://carshop.carshopinc.com/produc.../98457/CSP2370 swap plates. Get the plates or use what you have and try to install your engine.
