anybody have a mustang aje k member with no motor mounted?
i'm tryin to see if i can use their motor mounts on my setup. i have a team z k member for a sbc. the mounting perch is very similar on mine and aje's. can you please measure how wide the mounting point is where the motor mounts bolt to the k member? pretty much the inside width of the clam shell. also the distance on the k member from the two mounting points.
thanks a lot
mike
this will help make sense. i'm looking for measurement "B". and also the distance between the two pads for both "B" positions on the k member.
http://www.jegs.com/p/Moroso/Moroso-...44093/10002/-1
thanks a lot
mike
