1967 Camaro + 2006 GTO LS2 + Autometer Tach: How do I hook up my Tach????
I have had the LS2 in my 67 RS/SS Camaro for a few years now. I have every single gauge hooked up and working perfectly in my vehicle except for my Tach. I have looked at different wiring diagrams on the internet, tried hooking it up to different signal wires from the ECM, tried switching the Autometer (Carbon Fiber Series) gauge from 8 cylinder to 6 cylinder to 4 cylinder and I can't even get the gauge to move.
First question, can anyone provide me with a definitive answer as to which wire I should be using for the tach signal out of the ECM?
Second question, should the actual tach gauge be set for 8, 6 or 4 cylinders? (Everything I have read has said 4 cylinders since the LS engine is a 2 pulse system, I believe)
Third Question, what would be the best method to get this up and running, a pull up resistor (1K ohm in line, I believe), a tach adapter (Autometer or dakota digital) or another method possibly?
Thank you all for your help, insight and opinions!
Thank you for the reply
Read this about what he said about tach
https://ls1tech.com/forums/conversions-swaps/1449731-ls6-cobra-swap-speedo-tach-hookup-tips.html
