5.3 harness questions
My injector clips wont stay tight. it looks like all the connectors are broken does anyone know where i can get another set of injector clips?
Also.. is the o2 sensor plugings on the main harness or is it a seperate harness? I can't seem to locate it.
The O2 plugs (front and rear) are on the main harness. On mine there were some plugs that I couldn't identify. Used the info from LT1Swap.com and a ohm meter to trace back to the PCM connector. Then was able to identify by position on the Blue/Red connectors.
