What HP are you running with the Corvetter regulator?
Hey guys,
I'm doing a swap into a 66 Nova. The plans are staying with my stock sized LS1 bottom end (relief cut pistons though). 228ish cam from EPS, Stage 2 TEA 243 heads, LS6 intake, 4L60e trans, etc. Running a Bosch 044.
I'm HOPING to use the Vette regulator setup from Wix. What kind of HP are you guys running successfully with this regulator?
Thanks!!
Thanks!!
Thanks for the quick replies guys!!
What size lines did you run? Seeing that the vette reg is 3/8", I was going to use -6AN line as well. I'm wondering if trying to switch to -8AN might not be worth it due to the vette reg as a choke point for line size.
Any thoughts on that?
