BMW M3 E36 LS1 swap
Old 10-08-2011, 02:05 PM
Lil'John's Avatar
Very nice looking install... out of curiosity, do you think that stock exhaust manifolds/cats could be squeezed in?
Did you have to do anything extra for cooling?
What did you do for fuel feed?
Old 10-08-2011, 02:50 PM
Kaane's Avatar
Impossible to use any combination of factory LS manifolds. Steering shaft is in the way every time. Custom headers required and shaft goes between the runners.
I am using part of factory hard lines, I have AN fittings brazed onto the end of them, then they connect to Corvette FPR and Braided line from FPR to the rail with a EFI Adapter.
Here is a picture of the FPR assembly.
Old 10-08-2011, 05:12 PM
Lil'John's Avatar
So the driver side manifold would be an issue? Passenger side would work?
Do you think one of the stock manifold flipped upside down would work? (sharp turn on exhaust tube to run someway)
Mostly curious because of Calif smog. My stock engine is rapidly approaching 300k and I've considered an LS swap.
Are you using the stock BMW pump?
Old 10-08-2011, 07:14 PM
Kaane's Avatar
Walbro 255, but you can use a stock one until around 450hp.
Flipped manifolds wont work either.
Old 10-12-2011, 01:00 PM
Kaane's Avatar
Towing the car today to the exhaust shop and tuner finally!!
Hopefully will be done by friday
Old 10-17-2011, 04:35 PM
Kaane's Avatar
Had bad ecu, sucks I already spent money to get a HP tuners license on it. Had to pay another $100
Exhaust should be ready tomorrow and tuning should be done Wednesday.
Old 10-18-2011, 03:18 PM
BimmerLSX's Avatar
Car looks good! New Age has very nice products, guys took good care of me with everything!! Def would buy from again.
Old 10-18-2011, 03:22 PM
BimmerLSX's Avatar
This is the kit I bought from New Age, 2 in one fitting!.
http://shop.nahrods.com/LS-Engine-Fu...ne/P1019_1007/
Old 10-22-2011, 08:59 PM
Kaane's Avatar
Good news and Bad news.
Good news is exhaust is done and car was being dynoed.
Preliminary numbers it made 400whp and 380wtq.
Bad news is car lost fuel pressure 5 minutes later, 0 psi at the rail.
Replaced fuel regulator and it still sits at zero. So my brand new walbro pump took a dump! I hate those cheap *** pumps! Going to get a Supra Denso pump. So no car until tuesday
400whp would of been so nice today! GRRRRRR..........
Old 10-23-2011, 08:41 PM
AGearHead4Life's Avatar
love it!
Old 10-25-2011, 03:18 PM
Kaane's Avatar
Dynosheet.
Old 10-25-2011, 08:13 PM
  #32
rotor vs. piston's Avatar
Great numbers, great work. Must be a blast.
Old 10-28-2011, 06:00 PM
  #33
Kaane's Avatar
Dyno Video
http://www.youtube.com/watch?v=VHOh3ShfVTE
Old 10-28-2011, 06:41 PM
  #34
Andy1's Avatar
Kaane,
My Walbro (external) fuel pump lasted 15 minutes before it crapped out. Curiously, the replacement one sounds different and quieter.....maybe the first one was defective from the start.
Andy1
Old 10-28-2011, 07:16 PM
  #35
I've had my walbro for a few years now (unsure of the miles) w/ no problems. Used one in another swap and had no issues. There are a ton of knock offs out there though.
Old 10-30-2011, 08:18 PM
  #36
ken125's Avatar
awesome build! i have a bmw and I cant imagine an engine like that in mine! How the hell will that pass inspection in cali?
Old 10-30-2011, 10:29 PM
  #37
Kaane's Avatar
It won't pass emissions, since it's impossible to use any factory manifold in the E36 Chassis. Maybe one day someone carb's a set of headers.
Old 10-31-2011, 01:23 AM
  #38
fattydre's Avatar
So what are you going to do about smog test? Smog keeps me from wanting to do a swap in anything newer then 1975. I've already went through B.A.R once.
Old 10-31-2011, 10:10 AM
  #39
Kaane's Avatar
I smogged it before I did the swap, ask me in 2 years lol
Old 10-31-2011, 05:28 PM
  #40
GR33N GoblinM6's Avatar
did you retain the A/C?? pics of it ?
Quick Reply: BMW M3 E36 LS1 swap
