Alternator belt pulley needed
Old 10-10-2011, 02:32 PM
debreshnev's Avatar
Default Alternator belt pulley needed
I am using an alternator mounting solution from Bomber Fabrication that is a really nice setup but I am trying to find a pulley that can mount on the drivers side to give me enough belt wrap around the water pump. I am only running an Alternator with no other accessories.
If you look at this picture there is not enough belt wrap to work so I would like to add a pulley on the driver side that will work with the inside of the belt using a Camaro belt line.
For more pics of the setup please see: http://pirate4x4.com/forum/showthread.php?t=935877
Can anyone point me to a pulley setup that will mount on the drivers side that has grooves for the inside of the belt and be on the Camaro belt line?
