T56 Shifter Re-location & Output shaft Upgrades
This is a Ford aftermarket tailshaft housing. It came on the aftermarket "conversion tranny" for the Fox body Mustangs. I'm only using this housing because I got a deal on it. Otherwise these housings cost well over $500, and wouldn't be an option! It comes with the provision for the Ford manual speedo cable and/or Ford elec. speedo, which is going to be changed to GM electric speedo. Also, notice how long the housing extends out. 1.25 inches is going to be removed from the end of the housing, so it will match up with the f-body length. Then it will be bored to fit the TH400 bushing and seal. This will allow the 32-spline mainshaft to be used. Also, the shifter location will be moved back by using the Ford setup, 3inches (from centerline to centerline).
Here it is just as it comes, untouched..
Driver side
Passenger side
Top (31-spline in stock form)
For comparison, here is the stock f-body tailhousing (side view)
Top view
GM Elec Speedo Conversion
Close-up
New height of tailhousing, and speedo sensor installed
Ford elec speedo sensor, plug installed
Close-up
TH400 bushing/seal installed, for 32-spline SSR mainshaft
32-spline shaft compared to stock
31-spline yoke
32sp compared to stock w/ speedo gear installed
31-spline yoke
31-spline shaft w/ press-fit speedo journal added
Close-up
31-spline shaft installed in trans
Driver side
Passenger side
Top view
Close-up
Close-up
31-spline yoke
31-spline yoke
Close-up
