ok thinking of using a 8.1 here
Old 11-20-2011, 01:50 PM
Goat's ss's Avatar
Default ok thinking of using a 8.1 here
Me and a friend were talking about the LS engines the other day and the 8.1 came up and how we never heard of noone building them. So now I have decided to play some with one plans are as follows:
Switching to carb (not sure on size of carb yet)
2 inch carb spacer
custom cut cam over 600 lift
headers
I however have a old 79 malibu that this thing would be perfect for.
The specs on this motor is 550hp/690tq Im not sure if these are true numbers, but if they are thats nice to start with.
Have any of yall played with these before?
Old 11-20-2011, 02:05 PM
garys 68's Avatar
Does anyone make a carb intake or ignition controller for the 8.1?
You can probably fine more hi performance upgrade parts in the marine industry.
Old 11-20-2011, 02:12 PM
Goat's ss's Avatar
True and Im not sure on those parts yet, I know the made a marine model of this motor.
Old 11-20-2011, 02:18 PM
Pocket's Avatar
You can use the LS1 carb ignition kit on the 8.1
They are 24x engines and use essentially the same harness as a LS1, just a different firing order
Old 11-20-2011, 02:33 PM
TheLS1Lover's Avatar
I have always wondered why no one used them also, what is that like 500+ Ci?
Old 11-20-2011, 03:04 PM
garys 68's Avatar
496 cid but with a 4.375 stroke. Great motor for torque.
Check out Raylar Marine for 496 performance parts.
Old 11-20-2011, 03:18 PM
Goat's ss's Avatar
do they really make 550hp and 690tq though?
Old 11-20-2011, 03:31 PM
garys 68's Avatar
The GM version is not even close to those numbers.
Mercs marine versions put out 385 or 425 hp. They dont publish torque numbers.
Raylar is pretty impressive:
http://www.raylarengine.com/dyno.html
Old 11-20-2011, 03:37 PM
Goat's ss's Avatar
wel hell with wikipedia then cause thats what it said they were pushin
Old 11-20-2011, 04:01 PM
garys 68's Avatar
I'm pretty sure the GM 8.1s were only around 340hp and 460ft/lbs
Quick Reply: ok thinking of using a 8.1 here
