95 z28 ls swap ?'s
Old 11-21-2011, 09:33 PM
Shortbed70's Avatar
Default 95 z28 ls swap ?'s
Is it very complicated to do the LS swap into these cars with a th 350 or 400 trans? This is going to be a strip car only because it's not registered and it's gutted beyond repair... Or should I just put in a gen 1 sbc and be done??? If I need to change mounts and bunch of other stuff I can't afford. This is an EXTREME budget car!!!!
Old 11-21-2011, 09:39 PM
the_merv's Avatar
LS is pretty easy..expecially with a TH 350 or 400..
How big is the budget?
Old 11-22-2011, 05:43 AM
Shortbed70's Avatar
Well budget is small because I don't want to drop a ton of money at once. This is a secondary project so it will be an extra cash kinda thing. I would like to get motor,tranny,gears for under 2k. I have a guy that can set gear pack up, I can build the tranny and a guy says he can get me a motor for cheap. After building my last project it's not the major stuff I'm concerned with its the smaller things. Aluminum for interior,seat,belts,guages, mounts for everything..etc..
Old 11-22-2011, 06:47 AM
LS1Tech Sponsor
psiconversion's Avatar
You should be able to do motor, trans and gears for under $2k depending on how fast you want to go and how long you want it to last.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 11-22-2011, 06:48 AM
LS1MCSS's Avatar
If you're wanting to stay with an extreme budget, just go sbc and be done with it.
Old 11-22-2011, 06:05 PM
Shortbed70's Avatar
But I really want an LS... It will probably end up gen 1-2 motor.
